How do I cut Stainless boat lift cables?
Rob
I am replaceing the 3/16 stainless steel cables on my boat lift, I have the cables and need to cut them after I install them on the lift. I also need to cut the old ones off.There saying hack saw,bolt cutters, etc will not cut it. Must be some tuff cables.
Any sugestions???
Rob
Any sugestions???
Rob
there is a tool for it.. go to west marine, but this is what they look like
http://www.blueoceantackle.com/cutting_tools.htm
Ernie
Ernie
Charter Member #232
What they said. An air powered die grinder with a cut off wheel will probably give you your cleanest cut. I'd suggest a piece of heat shrink (shrunk down) right over the cut, it will keep the strands from unraveling and 'fraying.' A little water cooling would be good, too.
A torch will melt the ends smooth and keep em from unwinding.
Or heres the proper tool for cutting wire rope
http://images.google.com/imgres?imgu...icial%26sa%3DN
All the cuts for my installs was done using bolt cutter, you know the big ones that are designed for "honest" people cause they'll cut through everything.
When I did replacements and didn't want to spend the time to unwind the cables because you had to support the lifter beams then the cables just became a mess, I used a cutoff wheel in a hand grinder. Just went right down the role pipe...snip...snip...snip...ended up with a bunch of short cables.
If you don't have a pair of big bolt cutters, cut off wheel. The wheel is a cleaner cut as well. Wrap the end with tape BEFORE you cut.
