XR: swapping top cap, hydraulic steering issues
21 and 42 footers
I have the regular XR top and rear cap with the steering/tie bar mounted to the rear of the drive...see pics.
What do I have to do to swap the steering system to use this type of top/rear cap from the newer XR's.
Note: I have none of the hardware from these replacement drives so those items would need to be found as well......
Is this type that much stronger and warrant switching the steering system over.....I'm running 700 FT/TQ in a 38 Formula...also considering going to 5 blade props.
There is nothing wrong with the Latham set up and you have the showers to boot. I guess the new style upper case won't accept the old cap? Call latham direct the were very helpful when I needed some stuff that was missing. What are you doing with the old drives I need some parts or whole drive that I can rebuild. XZ's I assume.
JIm
JIm
OSO Moderator
If you want to swap upper cap for a stronger unit, you should be looking a little further than Merc. Get the Max Machine Worx cap.
EXTREMELY stout and guaranteed not to flex like Merc stuff.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
21 and 42 footers
The drive on the boat (first pic) is the setup I currently have. They are XR's but with the old style top cap. I bought 3 spares and a buddy will be getting 2 of them. Neither of us can use the top caps that are on the ones we bought (pic with drive on it's side in the back of the truck). Since this newer style top cap is stronger I'm looking to find a way to use them with my steering system. I won't have any parts leftover....sorry guys.
thedonz......check your PM's. I doubt I'll end up needed the extra setup you have but who knows.
Russ C.
Russ C.
Powerboat713
Drives and Lower Units
2
12-27-2007 10:50 PM
