Electric 3 way ball valve???
I am looking for a 12 volt electric 3 way ball valve to switch the exhaust water dumps from through the transom to fill a ballast tank? Anyone know of where I can find these? Thanks, Dave
Charter Member #139 /Moderator/Platinum Member
Dave
Do a search for Ball valves they have air operated ones You could use a silent choice compressor
and also 110 volt
http://www.mcmaster.com/
and also 110 volt
Kept the Bullet and the condo and joined the cig 20 restoration club.
3 Way Valve
Wardey, are you needing a valve that has three(3) ports? If so, this acually would be called a two(2)-way valve, believe it or not. Hope this helps.
Registered User
You're most likely going to find 24VDC electric or pneumatic valves. Other than line voltage, that's what the industrial standard. That is, unless someone makes an application-specific one.
Try Grainger.
Try Grainger.
Registered User
