Winterizing in climate controlled buildings
Speed is everything
I have always kept my boat in a heated garage but I winterize it as if it will be stored outside. Why take the chance. Remember Murphy's Law. If anything can go wrong, it will.
![Thumbs up](/forums/images/icons/icon14.gif)
Winterize, so it doesn't keep you up at night. The fact is that the question came up, so you already had doubt. Extra few bucks to fill with antifreeze. Less then a bar tab
Geronimo36
Extended storage. You should prepare your boat to sit whether its indoors or out. Protect the fuel system. Protect cooling system and external surfaces from corrosion. It's best to drain and replace with an anti freeze like propylene glycol. To drain and leave dry is worse then leaving water in it as far as corrosion goes. For what little it costs it's foolish not to do the best you can with it. Sure you can get away with less, but why?
Jim
Jim
I agree with Jim! Besides everything else it also provides internal engine protection to fog the motors.... I fog my lawn mower in the winter and snowblower in the summer...
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
In addition to that, if I'm working on a boat with a big lift cam and high seat pressure I also go thru and loosen up the rocker arms so all the valves are closed over the winter... The belief is the springs retain a memory from being compressed for a long period of time.... It may be overkill but only do it on big HP engines with big cams.
![Cool](/forums/images/smilies/cool.gif)
