Test driving boat, what should I look for?
Thinking about buying a boat this weekend and am going to test drive it on the water. What should i look for while im out on the test ride besides making sure the boats moving when the engines are running? It's a 1998 hustler 388 with twin
502's dynoed out at 600 hp a piece. Carberated engines, twin bravo one drives...what should i look for while test driving it?
There are many things, Maybe someone in the business to help you. A nine year old boat can hold many surprises. Basics would be condition of all fluids, temp while cruising compared to wide open. Oil pressure cold, hot , any variation port and stb. Prior to run compression test, Sound hull, service records, inspect drives and gimbles for slop. Does it idle smooth through out a long idle, or does it tend to load up. Do all gauges work? Do any fluctuate while running. Compare how it shifts in and out of gear port and stb. Good Luck
Jim
Jim
It would take me hours to type something, so I did a search online and found this from the www.about.com website. Basically plan on a 2+ hour inspection if your going yourself and make sure you look at every detail. This check list will come in handy for you. Honestly, I would seriously inspect it from top to bottom and if possible take someone in the boating industry like a mechanic. Whenever I buy a car, it takes me a good solid hour to thoroughly inspect it.
enjoy
USED BOAT BUYING CHECKLIST
TEST DRIVE - You wouldn't buy a car without test driving it first, would you? Same holds true with a boat, even more so than a car. Boats are finicky animals. They tend to require more attention and maintenance than cars. When you test drive the boat pay close attention to the following things while underway:
Vibration
If it vibrates it could mean a variety of things like a bent propeller. A vibrating boat makes a noisy boat.
Functioning Trim
If you're looking at an inboard/outboard boat check to make sure the trim works, which allows the motor to move from the down position to the angled position.
Response
Rapidly, but carefully, test the steering from one direction to another to see how long it takes the boat to respond.
Planing
Check to see how long it takes the boat to plane after take off.
Shifting
Does the boat slip smoothly into gear, or does it jump?
Reverse
Make sure the boat works in reverse. You never know how important this is until you have to dock.
Gauges and Instruments
Check the temperature, RPM, and speedometer for proper function.
Bilge
Make sure it is doing it's job. If your test ride is not long enough to tell, when you get back to the dock run some water in the engine hole with a water hose until the bilge kicks in.
It's a good idea to take along several people on the test drive. Added weight in a boat can affect it's performance and quickness.
HOURS
Check to see how many hours are on a boat. You measure a car's use by miles and a boat's use by hours. If a boat has more than 500 hours you can expect to pay some money in upgrades and maintenance.
CHECK FOR FLOOR ROT
Wood and water don't mix, especially in the floor of a boat. Carefully inspect the floor for soft spots, which indicate rot. Don't be afraid to get on your hands and knees and smell for floor for mildew.
MAINTENANCE
Ask for a maintenance history on the boat. Find out what major repairs have been made to the boat. If a lot of work has been done to the boat, chances are there will be lots to come, which translates into dollars. Ask if the boat is still under warranty. Also, ask who the boat owner used for repairs and make a point to talk to them.
MARINE SURVEY
It's a good idea to have a qualified marine mechanic thoroughly inspect the boat before purchasing it. To find a marine surveyor call either the Society of Accredited Marine Surveyors - SAMS. If you are going to do it yourself check the spark arrestors and plugs, alternator, belts, hoses, strainer, blower, shift cables, engine alignment, etc. Analyze the oil and make sure it is not cloudy or gritty Cloudy oil can mean the engine block is cracked.
HULL CONDITION
Take a walk around the boat and inspect the hull and make sure it is in good condition. Feel free to tap on the hull all the way around and make sure the hull is consistently solid. Mismatched paint is a sign the boat has been in an accident. Also check for gel-coat blisters and dry rot.
PROPELLER
Check the prop for warping, cracks, or nicks. Any of these things can throw off the performance of the boat.
STORAGE
How has the boat been stored while not in use? Was is stored outside and exposed to the sun and weather? Or was it kept in protected dry storage?
UPHOLSTERY
Depending on how the boat was stored can affect how the upholstery has held up over the years. Check for ripped seams and color fading. Also check the boat cover if there is one.
EXTRAS
It's nice if the owner will sell the boat with a few extras which are probably already on the boat. In my opinion, a depth finder is crucial. You don't want the boat to run aground, much less let your skier run aground. In most states a marine radio is required by law. A stereo is a nice thing to have so you can listen to tunes. Also see if the boat owner will throw in some life jackets and an anchor. And if you are a lucky slalom skier they may throw in a speed control device.
TRAILER
If a trailer comes with the boat you want to buy check the trailer thoroughly. They are not cheap to replace.
![Drink](/forums/images/smilies/drink.gif)
![Smilie](/forums/images/smilies/smile.gif)
Vibration
Functioning Trim
Response
Planing
Shifting
Reverse
Bilge
HOURS
CHECK FOR FLOOR ROT
MAINTENANCE
MARINE SURVEY
HULL CONDITION
PROPELLER
STORAGE
UPHOLSTERY
EXTRAS
TRAILER
http://www.boats.com/news-reviews/ar....html?lid=2786
more guides. this will help you get little more in depth.
ngine Check List
* Is there oil in the bilge? It may be a sign of an oil leak and warrants closer inspection.
* Are there signs of lubricant leakage around gaskets, freeze plugs and hoses?
* Are the hoses, belts and fittings cracked or brittle?
* Pull a spark plug and see if it appears relatively new, or burnt and poorly gapped. (This will provide an indication of how well serviced the engine is.)
* Is there a white chalky residue on the engine or drive? (This may indicate that it has been running hot.)
* Check the engine's oil condition and level. (If the oil looks milky, water may have entered, indicating the possibility of serious mechanical problems.)
* Check gearcase oil.
* Are the sacrificial anodes on the drive in good shape, or should they have been replaced long ago?
* Are there signs that the drive, rudder or propeller have hit submerged items.
* Look for signs of cavitation damage on the propeller(s), which is indicative of poor performance.
* Check for broken engine mounts.
* Compression check the engine.
If you do not feel qualified to perform any of these tests, then the best course of action is to get it done by a qualified technician.
Boat Check List
Aside from the engine, your inspection should also include the following:
* Check steering and throttle controls and cables.
* Switch on and operate all systems; bilge pump, blower, lights, stereo, winches, freshwater sink and shower, galley stove, head, heater, air conditioner, generator and so forth.
* Make sure all hardware is still firmly attached and check the condition of backing plates where possible.
* On a sailboat, check all rigging, hardware and sails.
* Open and close hatches.
* Check out the fuel tanks, fittings and lines. Be sure to smell for leaks.
* Are the batteries securely fastened in acid-proof containers?
* Perform an out-of-water inspection to see if there are dings or cracks. Also check for stress cracks, chips in the gelcoat, hull blisters and other hull irregularities.
* Is the propeller shaft and rudder stock straight?
* Is the upholstery in good condition and the stitching still holding?
* Does the cabin smell like mildew?
* Check through-hull fittings to ensure they are not loose and leaking.
* Check electrical items and connections for rust.
ngine Check List
Boat Check List
Geronimo36
When I bought the Scarab I went to look at it..... Thoroughly looked the boat over, top to bottom. Put a deposit down ($500 or something like that), did compression tests and leak down tests, then scheduled a test ride.
When I was idling out Pt. Pleasant inlet the sales person asked me if I was going to buy the boat today..... I turned to him, just as I was pushing the throttles forward and said; "I'll buy it as long as it doesn't blow up or sink."
Then when we idled back in the inlet after romping on some 3-4 ft waves he asked me how I would like to pay for it..... I said; "I'll cut you another check for $1K and give you the rest after the survey is complete."
He was a little pissed because he thought the sale was done but I bought the boat 4 days later and drove it home on the ocean that night......
I LOVE IT!! You have no idea how true that statement is with 90% of my test runs with customers!! I have found that the best way to avoid wide open throttle with someone that you have never ridden with before behind the wheel is to scare the hell out of them immediately. Then turn the controls over to them. They will generally go a little easier!!!
I LOVE IT!! You have no idea how true that statement is with 90% of my test runs with customers!! I have found that the best way to avoid wide open throttle with someone that you have never ridden with before behind the wheel is to scare the hell out of them immediately. Then turn the controls over to them. They will generally go a little easier!!!![Big Grin](/forums/images/smilies/biggrin.gif)
had compression test done and survey of the boat, everything as turned out well as expected the last of the deal is a test run. I will test run the boat tonight and keep in mind what everyone has told me to look for and i'll let ya know how it turns out. I know pretty good about boats but its always good to hear others opinions on things like this before spending money and getting into a situation, so thanks everyone with the help
