Why Apache are so expensive?
#271
#272
Also the Wider 33 might be a older style widebody Cig 36 which also has the same beam as the Scarabs...and the look...
Offtopic:
The highest hull number I´ve seen on a Squadron XII 39 is a 1981 model and no 8 of that year, a heavy mother that is bytheway...the bare hull weighs over 6500lbs ...compare that to a race 38 CUV at 5800 complete With Lambos and Sixes...and a Apache41 at 8600...
#273
#274
I´d agree with Chris on this one.
Offtopic:
Offtopic:
#276
Geronimo36
I think most of the pleasure 41's were sub 12-15K weights. El Indio's being one of the light ones. Not bad for a work boat!
#279
Registered User
IIRC, Mark has posted a weight of around 8500# wet & ready. I remember the pics from under the deck- you could tell someone's shoe size if they were standing on top.
#280
I was told all the weight lost with the carbon fiber lay up was added back in the structure of the boat thusly ended up weighing what a standard pleasure version would weigh. I think it will hold 300 gals of gas too. Interior only consists of two 6' settees and a 8' v birth. Two hanging lockers that are going to be removed have something different planned. There is loss of head room and foot room due to the 4 full stringers in the deck and the 5 full ones in the hull. Then theres the full bulk headss about every 18".
