86 formula 272 prop help ?
Is there any 272 owners that can help not sure what prop i should buy . my boat has twin merc 350's 260 hp stock with alapha drives it runs toped out 49 mph at 3900 is this right or what should i do they are also not ss props thanks.
'05 Concept SF23
My 85 272 would run 60 at 4800 RPM with cleavers. You have too much prop or your motors are tired. Also Formula had a performance option that had a higher than normal X height. The early 83-84 models had a fairly big rocker in the hull. Check on the Formula forum.
formula 272
do you remember what size dia the props were and what pitch? thanks
