Whipple Charger-
Old 11-30-2007, 02:38 PM
  #51
Rik
arneson-industries.com
Offshoreonly Advertiser
Rik's Avatar
Originally Posted by Ruaraidh
Newer Eaton devices are twisted but still do not feature internal compression. They still generate pressure at the exit port where the greater flow of the blower exceeds the engine's demands. This is a less efficient thermodynamic process.
HTH.
I wondered about the Eaton superchargers. They look a lot like a Lysholm. Thought someone else was just private labeling them.
Someone mentioned a patent. Apparently it has expired?
Rik is offline
Old 11-30-2007, 02:43 PM
  #52
Registered User
Originally Posted by VetteLT193
The rotors mesh on the Whipple (lynhsolm). the meshing it stops the leak back (through the intake) and creates compression within. In a nutshell efficiency is a whole lot better.
That still doesn't explain the differences.
Chris Sunkin is offline
Old 11-30-2007, 03:37 PM
  #53
Another nice thing with the Whipples is that they develop alot of boost at lower rpm's, great throttle response.
ApacheCarl is offline
Old 11-30-2007, 04:54 PM
  #54
Rob
Strip Poker 388's Avatar
Originally Posted by ApacheCarl
Whipples are awesome blowers. I have about 100hrs on a pair of 3.3s, no problems so far. They sound really cool when they are making boost
Carl ,Ya got a nice set up there
Strip Poker 388 is offline
Old 11-30-2007, 05:08 PM
  #55
Rob
First one is a Lysholm screw
2nd is a PSI screw
Chart shows roots efficiency
Attached Thumbnails Whipple Charger--lysholm_screw_rotors.jpg   Whipple Charger--psi-screw.jpg   Whipple Charger--roots_supercharger_efficiency_map.jpg
Old 11-30-2007, 05:40 PM
  #56
Rob
Whipple
Attached Thumbnails Whipple Charger--raceblower-whipple.jpg   Whipple Charger--whipple-screw-2.jpg
Old 11-30-2007, 06:18 PM
  #57
Eaton is now producing Lysholm type blowers. ie with internal compression.
However, AFAIK, they only produce these for the OEM market. Whipple produces for the aftermarket. I'm sure Dustin will be along shortly to clarify this.
Ruaraidh is offline
Old 11-30-2007, 06:36 PM
  #58
Rik
Rik's Avatar
I saw them, Eaton, at the LA Roadster Swap Meet. They were trying to sell them to the roadster guys. Looks just the same as a Whipple but they made a shaft to turn the blower around.
Rik is offline
Old 11-30-2007, 08:01 PM
  #59
Thx Strip
How many hours do you have on your 3.3's now ???? Just curious what you think the rebuild interval on the blower is.
Old 11-30-2007, 08:29 PM
  #60
GT
GT's Avatar
Originally Posted by Sacred Ground
Thinking about going to Quad Whipples and selling our 871TBS and carbs-
Who has Whipples and how to you like them?
They make a superior product IMO. Along with the quad, the W305 is also a good choice from Whipple for a big HP motor. Super smooth efi linkage too.
Whipple is a company that has really pushed hard for a long time and it shows in the performance/reliablity of their SC's. If I were you, I would not hesitate to purchase one(or two) Whipple's from your local distributor.
Gary Taylor/TPI
GT is offline
Quick Reply: Whipple Charger-
