Livorsi Rims Turning Colors >
Old 12-27-2007, 02:51 PM
Originally Posted by Big Cliff
Liv's are the cheapest made gages. Go AutoMeter if you want quality.
I thought Autometer makes Livorsi gauges
VetteLT193 is offline
Lofty's Avatar
Might want to take a close look at Livorsi faceplates. They are made by AutoMeter for Livorsi.
Lofty is offline
Old 12-27-2007, 02:54 PM
Lofty's Avatar
Take a close look.
Lofty is offline
Old 12-27-2007, 02:56 PM
Lofty's Avatar
Livorsi has given us GREAT customer service so I would suggest if you're having problems you send them to Livorsi for warrenty work. They can replace the bezels for you. They've fixed GPS antenna leads for us many, many times at little or no charge.
Lofty is offline
Old 12-27-2007, 03:01 PM
Big Cliff
True, but Liv wants the cheapest parts to have a large profit margin. Products and quality controll are much lower on the Liv's.
Not trying to start anything, but how many people with Auto Meter gages are having problems?
Old 12-27-2007, 03:15 PM
Lofty's Avatar
Don't worry, you're not starting any chit, you have a good question but I don't know that I agree with the QC issue with the Livorsi gauges.
I know that I miss the old liquid filled gauges. In fact I run a set of mechanical liquid filled oil pressure and water pressure gauges under the hatch that I use as a sanity check against the panel gauges. I've had my share of electric gauges failing and sending me home early.
Lofty is offline
Old 12-27-2007, 04:47 PM
And to think I was going to replace all my gauges with livorsi gauges good thing I read this. I thought the Livorsi's were a little pricey.
prosno is offline
Old 12-27-2007, 04:59 PM
Rob
Strip Poker 388's Avatar
I would bet the Livorsi and Autometer has the same guts. Livorsi is probably plating the bezels after they get it from Autometer.
Also my Livorsi exhaust temp gages only work about 10% of the timeI even bought new thermocouples and new wiring.
Smiklos I have 2 of there electric fuel pressure gages and senders , Sent them in for calibration,they sold me a sender for 40.00,the Autometer one is 12.00 and now one gage it off 15psi and the other is 7 psi off.I just use them as a reference to see if there's a problem,But in a blower motor if it dropped much it would hurt it
Also the sender has VDO on it
On my race car I have the Autometer electric furl pressure gages, It comes with a 2 wire sensor and the electric box (under dash top LH in the pick). These are within 1psi.
Strip Poker 388 is offline
Old 12-27-2007, 05:08 PM
its funny whats in a name I figured the Livorsi's were real high end the best of the best. Oh well factory gauges still work I'll leave them alone for now
prosno is offline
Old 12-27-2007, 05:22 PM
Charter Member #232
Audiofn's Avatar
You want reliable buy the cheapest guages out there. They seem to work better then any of them. Like Teleflex. When is the last time one of them has not worked!! It is the same with my high end stereo gear that I sell, the higher end the more finiky it is.
Put your best foot forward!
Audiofn is offline
Quick Reply: Livorsi Rims Turning Colors
