Diesel engines in speed boat
#401
WOW - a person that's defends me!!!!
Good job - 29Firefox
Jassman - serious questions, does Nortech offer a diesel boat with anything other than Yanmar? Is there a relationship between Mastry and Nortech because I have never seen a Nortech with anything but Yanmar? Why did you build one with Yanmar over Cummins, Cat or Seatek?
Just lòok at the two engines side by side, then look at the heart of the engine, the cranks. Look at inline cummins and 7.3 IH or duramax... everything about the cummins is beefier. The v8 crank is no match for the inline cummins when it comes to strenth rigidity. , the shared throws are so much weaker on a v8 and there is so much more bearing area supporting the I6 crank. You dont need to be an engineer to see all the benefits of the 6. If v8 diesels are so great why are junkyards littered with GM 6.2 and 6.5 engines that are actually best suited for use as mooring anchors.
#402
I have a question for you joe, on running a diesel boat like say a 41 saber/apachce with a pair of cummins diesels in it with arnesons.
When you leave the water coming off big waves the diesels dont throttle up and down quickly , correct?, like a gas engine coming on and off of the throttles. ld think would let the turbo spool down enough for it to take a little while to be back to where it was when you chopped the throttles.
That being the case, Whats the best way to run a fast diesel powered boat in big water.
Have you ever tried a jake brake or driveline brake to unload the drive when youre air born.
i would think you do not want to over speed the engines or land with the throttles wfo
Ĺike when the posche turbo cars race, the diver stays on the gas and slows the car using the brakes but never fully coming off the gas so the turbo is always spooled up.
It would seem the instant on/off of a jake brake would have the engines at max power quicker.
Thx for sharing all your hard earned diesel knowledge with us. Rm
#403
There,s a fountain called Blast off here in the uk that races with twin 440 yanmars which can hit about 80 mph and hit 84 mph at speed record week on the Lake .
You can get more imfo at Blast off racing .
#404
Received 1,286 Likes
#405
#406
Bob
Bob
/Users/robertbarnhart/Desktop/Ft MyersLogo 4.jpg
#407
