Aluminum Cylinder Heads & Salt Water
Dean,
I have nothing positive to say about Tom, the entire business experience from service, quality of work to integrity. Do your home work. You might try Tommy Hoffstetter for input.
What are your goals with the HP 500 heads? At a minimum, see what Jim V thinks about these castings...not sure there is a lot to gain.
You need to call me to discuss aluminum heads in salt water. There is a BIG issue with bolting heads based on gen IV heads with round water passages on gen VI blocks with oblong water passages. Too long to relate to you on here but we can discuss. I have personal experience with this, you are right to be skeptical. Some people get away with aluminum heads in salt water but I did not and I will tell you what to look for.
I have posted pics before, do a search.
Call me.
Tom
337-513-1133
Call me.
Tom
337-513-1133
Long time cult member.
BTW there is a guy with the same boat as you on the board, WAGS382 that put AFR heads and Bob Madara cams and picked up 7 mph. Do a search.
I talked to wag382 already but he runs in fresh water, I do like the numbers he gained. As for Bob he will be making me a Cam no matter what heads I use.
OSO Moderator
I just looked at a set of Edelbrock heads with only 70 hrs on them only 2 years old and they need to be welded up and they maybe wasted. This guy flushed them out and used Salt away. He has not left the boat in the water over night and always said I need to go flush out the motors after we go out for the day. I don't know what heads I want to go with now. I was going with Dart Pro 1 but after looking at the Edelbrocks I may stay with Iron Heads .I don't want to piss money away I already have a boat enough money pissed away already.
My engine builder; Joey Griffin, used Fel Pro gaskets. His thoughts are the Salt Away ate up the gasket on my motor and the guy that has the Edelbrock alum heads referenced above.
He used it EVERY time jusy like I did. My iron heads corroded out and I flushed my boat RELIGIOUSLY w/ Salt Away.
http://www.offshoreonly.com/forums/s...31#post2712531
My heads corroded out around the oblong water passage. The one with all the rust is the one that let go, but the other head was "on it's way"
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
The main thing to note here is " He used Salt Away"!
Dean
Everything is for sale @ a certain $$
KEPP
New Products and Member Discounts
0
05-21-2005 11:57 AM
