Aluminum Cylinder Heads & Salt Water
Is anybody using aluminum cylinder heads in salt water and if so are they holding up ? What manufacture are you using ? I am looking to replace heads on hp500 carb motors, I'm looking at Dart pro1 310's or AFR 305 or 315cnc.
Joby
Joby
Im running Dart have run brodex both having no problems.
Tha t said I try to flush after every trip.I have heard canfield dont hold up as well.I have run aluminum for over 15 yrs and would never go back to steel.
I hate the winter!!
OSO Moderator
Joey Griffin put aluminum head on Jon B's motors. So far so good!
As long as you flush it religiously you'll be fine.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Dilligaf3268 (07-01-2023)
The Illustrious One
Dart are very good just make sure you flush the salt out of the engines very thoroughly and use a product called salt away and when the foam bubbles come out of the tail pipes shut the motors down
Dying,....Is the day worth living for!!!!!!
