Safety Straps
SeaRay Sundancer
I have the same issue. It is certainly not bouncing at all but you never know if you had to swerve off the road or something. The front of the boat is secure and not going fwd or back, but I like the back to firm on the trailer.
The easiest fix to the problem is to just drill a 2" hole in the middle of the K plane for the strap to go through.
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
Seriously though, I think you will be OK to run the strap around the tab. I don't think it will hurt anything. I did it for a few years on my 28 Pantera and just padded the strap where it contacted the tab to prevent it from rubbing. I found that the fuzzy seat belt wraps work well for this job. You know, the ones you see in all of the automotive stores that are supposed to pad your neck to keep the seat belts from rubbing.
Look at the tension on this strap/tab after we got whacked while making a right hand turn. This strap was under extreme tension after the accident and it didn't do any damage to the tab. After experiencing this, I personally don't think you will have any problems with the strap going around the tab for normal trailering conditions.
Good point. I never thought of it like that, but I would stick to the heavier straps to take the 7500 pound load.
I'm just kidding, please DO NOT do that.
Nordic95
Thanks hot duck: that is some extreme pressure, and that is far from the pivot point stressing the hinge even more. I guess those K planes are stronger than I thought.
Registered User
On both my boats, the d-rings on the transom are directly above the tabs. I use a 2" flat strap with a hook end thru the d-ring, then fish the strap thru the hinge area of the tab and down to the ring welded on the trailer, the ratchet end goes there. It's a straight pull downward and since the tab hinge area is radiused, there's no sharp edge to wear on.
As far as what straps to what, the assumption is correct, you are retaining the lesser of the two weights. At the same time, when SHTF, you can't have enough strap. If the boat bounces off the trailer while you're in the middle of a picture-perfect recovery from slipping off a berm, your afternoon is shot.
I cant remember where we got these, but I believe they are rated for 3500# each. We tow several times a year between Punta Gorda, FL and Indianapolis, IN (1100 miles) and have never had a problem.... We check them tight at each fuel stop
AT Cult Member #3
