Borax and vinyl
Try mixing a solution of chlorine bleach(20-25%) and water in a spray bottle. I used to have a bad mildew problem when I lived up north with my boats. Mold and mildew over the winter. I tried everything and this worked the best. After cleaning I followed up with a good vinyl treatment and UV protectant. The bleach brings out the color and whites of the vinyl. Just make sure you rinse it good immediately after cleaning. I use this anytime I get mildew on life jackets or outside furniture.
I don't have a problem with mildew or anything. I just happened to come across an article about borax and baking soda,and was wondering if it would work for cleaning vinyl. I know it's used to help get clothes clean so you don't have to worry about the stitching like you do with bleach. I was just wondering and thought someone here has tried it.
What i like about it is you can make a paste with it to remove stains and its not toxic. Also they said it removes rust stains from stainless,porcelain,ect, thought maybe it would be good for cleaning our hulls.
do NOT use borax or bleach or any other chloride on vinyl
(ie pvc, poly vinyl chloride) as the chloride base of these cleaners will break down the PVC molecule, openin u p the molecular structure where dirt and staining quiclky occurs
it looks awesome and blinding white when first cleaned but you will notice that it stains very quickly again, and a anever ending cycle
I'm just a mechanical engineer but this was told to me by a chemical engineer co worker.
i have had the best luck with 3m vinyl cleaner
Ramb
Ramb
Magic Eraser !
Try this guys. Magic eraser is the best thing....really try it! You can get it at the local market in the cleaning section. Mild soap a little rub and its bright white again. Amazing
