Blackhawks
Old 05-23-2008, 07:03 PM
BY U BOY's Avatar
well his reserve is 3k each, with the props.
BY U BOY is offline
Old 05-23-2008, 07:05 PM
offshoredrillin's Avatar
Received 1,297 Likes on 449 Posts
ok, i have some one about 40 miles away that can pick them up. I dont want to step on your toes, are you sure your boat will work with them, you need lots of rocker to get wwater to them.
offshoredrillin is offline
Old 05-23-2008, 08:04 PM
Neno the mind boggler
glassdave's Avatar
you also need enough X dim to get the bullet out of the water. If not it will cause excessive transom lift forcing the bow down. Otherwise a pretty good drive and as Airpacker said you probably will not be able to spin it with the current set up. Thats alot of prop and gear
08 OPA High Points Champion
glassdave is offline
Old 05-23-2008, 08:07 PM
Registered User
I bid on them last time- they only made it to about $1100 each. I was surprised.
Chris Sunkin is offline
Old 05-23-2008, 09:30 PM
Registered User
The reserve is $3000 each and the reserve on the boat w/o engines and drives is $11,000. They are keeping the transom units with the boat cause it's a jackshaft setup and they wanna keep the value of the boat up
29Firefox is offline
Old 05-23-2008, 09:48 PM
BY U BOY's Avatar
Rob you have PM
BY U BOY is offline
twin242ls
01-17-2008 08:56 AM
BY U BOY
Scarab
0
08-15-2007 06:05 PM
Lake Front
Pantera
2
01-14-2004 01:48 PM
HiPerf2000
3
03-11-2003 05:02 PM
wwwTOPDJcom
07-22-2002 12:19 AM
Quick Reply: Blackhawks
