Skater Fuel Tank Replacement Update Questions
with the skater fuel tanks,resin deteriorzation leaking problems and needing to be replaced due to the Alchohol in pump fuels, Is there anyway to detect or see if they have been updated without cutting holes in the boat, Heard the update to new tanks is around 10k from Skater. Is this problem limited to Skaters only?,
Call Double R Performance in Canada.
They did mine with new bladders in my 32 with 3 x 300s 2 years ago.
They got right into the subject with Skater and others when they were investigating the problem.
Ask for Raymond 1 705 487 7575
Tell them Alec sent you.
Hope that helps
Hope that helps
