Holes in Drives
Old 08-11-2008, 04:29 PM
Default Holes in Drives
Has anybody ever drilled more holes in bravo drives. I would like to get more water flow through the motor and thought that somebody told me that they did this before..
Appreciate any info on this thanks....
JeffC is offline
Old 08-11-2008, 04:32 PM
GLH
GLH's Avatar
Get some independent water pick ups and plump the drive water to act as a drive shower.
Notwithstanding I think the bravo holes bring enough water to most engine Bravos can accomodate.
GLH is offline
Old 08-11-2008, 08:01 PM
Forum Regulator
Sydwayz's Avatar
Received 1,249 Likes on 542 Posts
Do you have...
Low Water Pickups? (4 holes in the nose of the bullet)
Side Water Pickups? (6 holes or so on either side of the lower)
or Dual Water Pickups? (both sets of holes)
If you have one or the other, switch to a lower with dual.
If you have Side Water Pickups, you can chamfer the holes and make a little more of a channel for the water to enter the front side of the holes, which will increase a few pounds on some applications.
Sydwayz is offline
Old 08-11-2008, 08:06 PM
What is happening?
jeff1000man is offline
Old 08-11-2008, 08:07 PM
I have a problem at high speeds with a high x dimension and side hole pick ups. I loose water flow on the upper holes and she starts to get a little warm under there,
Old 08-11-2008, 08:10 PM
Forum Regulator
Sydwayz's Avatar
Try chamfering the holes with a Dremmel tool like I mentioned. A buddy of mine picked up 9 lbs. on a Checkmate 251 a few years ago doing this.
Sydwayz is offline
Old 08-11-2008, 08:16 PM
THat is a lot cheaper than changing the housing.
I might exeeriment with a regular Bravo first though before I go cutting on a perfectly good new XR.
Old 08-11-2008, 08:35 PM
hillbilly24's Avatar
Also try plugging the top hole or two on both sides, on boats with high X's you can suck air through them. Not uncommon. Start with just one whole and go from there, you can tap the existing hole with a 1/8" pipe tap and screw a pipe plug into it.
hillbilly24 is offline
Old 08-12-2008, 08:50 AM
you could just get a Bob's nose cone with the low water pickup.
http://www.bobsmachine.com/products/...ne_Bigfoot.cfm
VetteLT193 is offline
Old 08-12-2008, 08:55 AM
There is a size smaller too, I think its 1/16 pipe
MOBILEMERCMAN is offline
Quick Reply: Holes in Drives
