Dyno-Flo Engines
I did a search and didn't find too much about them on here. Their 540 looks like a nice package at a great price. Anyone here have experience with them?
Marine 540 Pump Gas 630 Horse Power
Dart Big M 9.8 Deck Nodular Caps 4.500
SRP Pistons Forged CH Flat Top 9.7:1 ceramic coated crowns
Eagle 4340 Forged Steel Internal Balance Crankshaft 4.25 Stroke BBC
Eagle 4340 Forged Steel H Beam Rods with ARP L19 Rod bolts
King Alecular Pro Race Bearings Rods and Mains
Mahle File Fit Performance Ring Set
Balanced and Assembled
Dart Pro 1 325 CC Alum Heads- Fully Ported and Flowed
118cc Chamber chambers and valves ceramic coated
Assembled For .660 Max Lift
Stainless Valves
1.63 Valve Springs
Titanium Retainers 10 degree locks
Aluminum double bar stud girdle
ARP Headstuds
Comp Cams magnum Roller Rocker Arms
Mr. Gasket Solicore Head Gaskets or Equivalent
Single Plane Intake Manifold
Comp Cams Hydraulic Roller Camshaft
Comp Cams Hydraulic Roller Lifters
Melling High BVolume Oil Pump and Shaft
Professional Products SFI Internal Balance Damper
Milodon marine Pan
Billet double roller timing chain w/ torrington bearing
Aluminum Valve Covers
Dyno+Tune
$10,999
Stainless Valves
1.63 Valve Springs
ARP Headstuds
Milodon marine Pan
Dyno+Tune
$10,999
21 and 42 footers
Yep....I have Mellings 10778 oil pumps and make nearly 80 psi cold, 65-70 psi running and at temp. No problems but it could happen (knock on wood...)
This is no knock on dynoflow. Theres a list of good parts there. I think the Eagle cranks are forged in China and finished here. I would upgrade to a callies crank which Dynoflo also sells. A good engine really comes from who is putting these parts together. You want to use somone with experience putting performance marine engines together. There are some differences that need to be paid attention to.
ONESICKGLADIATOR
08-25-2005 12:44 AM
