New Cummins/Mercruiser Project
#101
Registered User
1 Post
It will be "accurate". Just "proportionally" lower. Just mark the zones on the gauge so the operator can understand whats going on. I use automotive decal vinyl around the outer edges of the bezel it sticks to the glass real good. Operators don't always read the numbers on gauges right. Anything important like oil pressure, coolant temp, pyrometer etcetera get some green, yellow and red so the operator can tell at a glance what his status is.
#102
#103
Registered User
1 Post
On my other diesel boat ,a Sonic 28 with a Yanmar 6 LY ,I needed a bellhouse for a bravo to yanmar 6LY ,I called a lot of people in the US ,and did a lot of search ,but could not found a bellhouse ... I used a tailstock and a special made splined adapter to make the connection between enginea and drive,I was thinking about making one from a solid plate ali
If I only knew where to buy one back then...
#106
Registered User
Backside of the dash...processors galore...
Full interior cabin going at the same time...
New sea strainers developed by Teague...
New design corrison-resistant NXT drives...
Drivetrain will start with 1.35 gears and labbed 38p 5-blades, targeting 75-80mph running speed...
#107
Registered User
1 Post
No Bling Bling?
It's looking like a good straight clean install..... Just a minor suggestion from the peanut gallery..... On the step on surfaces polished stainless steel diamond plate. On all sides and bilge 1 mm mirror polished stainless steel. It makes wiping up messes real easy and sets every thing off.
#108
Registered User
