maximus surfacedrive
arneson-industries.com
Offshoreonly Advertiser
Julie, he has a fixed shaft drive installed in a surface mode. (Ski boat setup mounted at the stern)
The hub of the Maximus is 4.75" in diameter. The diameter is limited to 15.5" I belive. This leaves a blade area of only 5.375" per blade. It will be difficult to get on plane but Yes, once it is on plane it will push the boat.
Efficiency is the question. The hub will cause some issues but the biggest obstacle is getting it on plane. Then it will come down to slippage and engine rpm.
I belive Gerard wants to try the Maximus for the rake it offers in order to see if it gives him bow lift. Answer will be determined by his fixed shaft angle and how much it is hampering his bow lift efforts.
thanks rick for your input i really appreciate it
hi julie my max dia is 17.5 currently running a 17x24 merc 4 blade cleaver 58 mph
altho i had best results with a chopper type prop 16.25 dia 24 pitch 64.5 mph
i really appreciate the help here guys
