Oil Temp What's to hot?
Just seems like everything that I read about oil temps says that an engine should always maintain AT LEAST 190* oil temps, and if a 212* thermostat is not installed, the engine should be run hard enough for enough time to get the oil temps up to over 212* in order to burn off condensation. maybe some experts will chime in and let us know what the deal is.
If this isnt necessary, I can sure save a lot of gas by not running 5000rpm all the time and cruise all day at 4200rpm with 180* oil temps.![Lolhit](/forums/images/smilies/more/lolhit.gif)
SORE MEMBER
1 Post
250f max is fine and wont stress modern oils. You have two groups of people posting here. One is measuring oil temp after the cooler and the other is measuring in the pan.
A big offshore cooler like Teagues reduces oil temp 50* so 250 pan temp is 200 going back to the motor.
What I would recommend regardless of where your oil temp is measured is a good quality synthetic oil such as Mobil-1 v-twin 20/50
