Drive u-joint identification PLEASE
21 and 42 footers
Just bought a Merc re-man XR upper. The U joint looks different than the ones on my 2002 drives.......did Merc change the design of these over the years? If it matters, the "reman" is the old style just like my 2002 case.
and, they didn't put the "finned" XR top cap on as I requested 6-7 times. I'm not sure but are there any shimming issues I need to address when I finally get the correct top cap (meaning, can I just swap the top caps once I get it?)
That is a gkn, style u-joint, some have external snap rings others have internal clips, depending on what serial # drive you have the snap rings come in different thicknesses for proper fit of the u-joint. I believe the rebuilt u-joint is a newer serial number due to the smaller size of the cap, both will work the same. As far as the top cap goes; the gear back-lash should be .009-.015 with the proper checking tools. If the drive you are using is driving the lower gear forward you will be ok, but if it's the top gear driving you forward, it needs to be checked.Do you have a local shop that is qualified to do this? I can help if not.
21 and 42 footers
