Stepped vs Deep V
Not to beat a dead horse, but I have a few questions regarding stepped hulls and was hoping the offshore racers might be able to offer a different perspective from my fishing forum.
I have the option of a stepped hull on a 31 foot CC offshore fishing boat or a conventional V. I fish off the coast of South Carolina, and usually encounter 3 foot seas. I run to the gulf, approx 50 miles each way, and want a faster ride.
The advantages of a stepped hull, as I am told, are faster ride and increased fuel efficiency at cruising speed. The V hull tops out at 65 mph with twin 350 Yahama 4 stroke outboards. The stepped hull, I am told, can do the same with twin 250 Yamaha 4 stroke outboards. They are on hull number 3 of the stepped hull, and have yet to power one with twin 350 Yamahas.
So what are the compromises, if any, of a stepped hull? How different is the ride? Are they hard to handle? Do they track well? How about slow speed handling (no wake zones might compare to trolling in the ocean).? Are stepped hulls better in lakes versus ocean? Do they spin end over end if I turn the wheel after hitting a wave?
Thank you,
Jason
Thank you,
Jason
Length 32-7
Beam 9-8
Weight loaded 11,560lbs, dry 5850
Draft 23 inches
Deep V 24.5 degrees
http://www.contenderfishingboats.com/boats.aspx?id=454
I am led to believe the stepped hull has identical dimensions - with a $6K higher price tag.
Thanks,
Jason
Beam 9-8
Draft 23 inches
Deep V 24.5 degrees
Thanks,
Jason
I can tell you from experiance that a 30' boat with two big heavy 4 stroke's hanging off the back will be a single purpose boat , it might be fast, but the trade off is not worth it , make the company build it first and run it in all types of water before you committ , because once you own it , it,s yours !!!
RHC
RHC
You should take a look at the Renegades also. These boats are built well and rigged well. Handle the ocean well also. Great people to deal with. You have a choice of stepped or non stepped hulls and they will sea trial you in both. Latest model is a 38 Footer, You will also have quite a bit of coin leftover versus the contender to put in your fuel tank.
The stepped is only going to help you in the flat water of the ICW, I live north of Myrtle Beach and run the ICW to L.R inlet out to the ocean all the time, you can spin a stepped boat out at lower speeds in low trim settings in turns. Trolling no difference. The chop of the ocean is going to make up for no steps. We only have a few days out there that the ocean is lake flat, without the s.e. winds.
![Coolcowboy](/forums/images/smilies/more/coolcowboy.gif)
![Evil](/forums/images/smilies/evilB.gif)
