Mercury 700sci problem
If I read Dustins post correctly, he is not apparently saying the battery is causing the problem, I believe he is saying its a computer problem, shorting out a ECM circut that is being caused by an IAC overload or something.
Mercury uses a Ford type IAC motor and I know these are sometimes proned to burn up from the high amperage load they can create when they start going bad.
Sounds like something Mercury has seen before, I am surprised they don't have a technical service bulletin or something out about a fix or something?
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Dustin,
I was the one who lost 2 computers with the ICA valves in one month. If it is the valve taking out the computer can a inline fuse be installed between the to for protection of the computer? The first question from second mechanic that looked at my boat was do you have deep cycle batteries. He called mercury to try to get it warranty and that was the same question they asked. I don't understand it either but they say the batteries have a memory and produce high voltage spikes. So that is why I changed the batteries plus they were getting old.
Bob
PS: Are you working on a fix for the bad computers or only to try to stop burning them up?
Bob
I have a stack of PCM's here with the same issues, and some with other issues that we are repairing. The IAC repair is tough, but were getting it. We can repair all coil driver failures, which is also a common.
Thank you for all your quick responses. I will be looking forward to see if you come up with any solutions to the ICA and computer burning up. Once I change my drives to something stronger I will be ready for a upgrade on these motors.
I've never seen a voltage spike up from deep cycle batteries, but I can say that I've maybe only data logged it 2-3 times and it would be impossible to test all scenario's, but I really don't see this is a high voltage spike. There is already a fuse tied to this circuit. I'm working on an extra circuit that plugs into the IAC and bypass valve connectors that has extra protection, high and low, so I'm working on that now.
Mark
