sneak peak/ fastest 42 tiger engine
#121
If anyone can make it right Mark, you can!
for those newbies that dont know of Mark, his site is http://pmefi.com/ he built and throttles the 40 skater for AJ's no plans poker run team. knowledge, common sense and honesty isn't just talk, it's how he runs his business. when it comes time to relaxing and having a beer with you, he is one of the best in the industry.
I owe my set up to him, thanks again Mark, happy new year!
#122
#124
Hey Mark, the dyno went down at southland machine a couple weeks ago during the pri show, Mr Ronnie is supposed to receive the part he needs to get up and running by next week, if all goes well with our R&D there, i will still be coming to Precision with all marine equipment on engine for our endurance dyno and tune with u guys, look forward to it. Mark you and Billy or first class guys at Precision and would recommend yall to anyone seeking repair, maintnence, or custom design.....Happy New Year to all!!!!!!
PS. its fun on here bench racing and boating on OSO, but im ready for the D--m summer!! Thanks Doug
#127
+1
#128
Geronimo36
![Smilie](/forums/images/smilies/smile.gif)
Just finished rebuilding one of my 800's for the Apache... I'll be firing it up in a few weeks.... Hopefully I don't make no kaboom!
![Grinser010](/forums/images/smilies/grinser010.gif)
Once the engine is done I'll be shifting my focus to rebuilding the lowers on my drives.
![Drink](/forums/images/smilies/drink.gif)
#129
Hello Gatorone, not sure what u mean by standard heads, aluminum, conventional maybe, was going to run big chiefs heads but worried about geometry issues, i am a realist though and understand we may not achieve these numbers on 93 oct. in my opinion detonation would be our enemy on making big hp on pump gas, u cant see in the pics, but i have methanol injection which should aid a little in detonation as additional boost is applied, do you have expierince with similiar engine combos?
Methanol injection has to be properly placed on a screw compressor, it does not work like a roots, which just sweeps air from top to bottom. Screw's move the air axially through the housing, then compress as it gets discharged. Methanol will evaporate before the highest point of compression, thus negating the biggest temp drop. The closer you can get to the compression phase, the better cooling/results you'll get.
#130
1500hp on 93?...... Good luck. 116gas would be easy. Seriously, after your first dyno pull, you will have trashed that motor. How hard are you spinning the blower. 1400hp with 23* heads and 50% over crank speed is a good number to shoot for. But try it on 110 gas. 1200hp on pump gas is reasonable for that setup. It's not worth trashing that nice looking motor
