Supercharged Ilmors
Before I would ever supercharge an Ilmore marine engine I would talk to the actual people at Ilmore!
They know that engine inside out and they would probably share their thoughts with respect to reliability and practicality of the possible conversion.
You know they could probably either rework your engine up to their 710-725HP level or sell you the required parts and pieces and give you more power without the supercharging.
Just a thought.
When you have a question, go to the experts!
Just a thought.
I do not know. I did not ask.
I expressed and have -0- interest in a blown version.
After f-ing with all the air pushing stuff my whole life I have standardized on very expensive Na/injected mills for personal use.
Its usually waay more expensive per HP, but Ive changed so many supercharged marine engines in my life Im done.
UD
Good question Cat.
UD
UD
Although those tall deck blocks usually have severe valve geometry and short life, but- really honk..
UD
Diamond Member #001
Would they offer any ideas as to what it would take to convert your 625's to 7-10's? If was as simple as a cam change and ECM programming, it wouldn't be too bad. On the other hand, if it involves head work and a different crankshaft or something, that's a whole nother story.
Still, I can't help but think that a blower development program would have to be very expensive.
Go big: Sonny Leonard 892, 2034 hp, no blower. (Can't speak for the durability in a marine application, though.)
I like them stock..less failures, proven marine design, look cool.......and naturally asprated..
I will say I did talk with Wayne, the guy who bought my Nor-Tech.. The 700 Mercs he thought he had 180 hours or around there...not one problem..those are stock as well. To me trouble free boating is what it's all about..Good Luck guys.Jeff
Is your 625 ready for a rebuild or do you just want more power. If it isnt rebuild time why f with it?
All due respect to the auto guys using this base block to build huge power in an auto app - I wouldn't try to duplicate these techniques in a marine app the duty cycles is vastly different. I would consider headwork and an cam ecu change but not forced induction without serious testing and then I would only do a mild bump say 10 ponies or so.
(ilmors are supposed to last huge hours with some guy claiming 600+ now with only fluid changes)
What was the delta ilmor quoted you?
Uncle Dave
