x dimensions
hey guys i need your help im fitting a bravo on a pantera 28
but i havent got a clue what x dimensions means
i was told 1" but where do i measure from and to
any help would be great
cheers
cheers
Charter Member #139 /Moderator/Platinum Member
x-dim refers to the distance from the bottom of the hull to the center line of the crankshaft.
On a standard bravo the distance from the prop shaft to the input shaft is 21-13/16
I am assuming the 1" dimension you talk about is having the prop shaft 1" below the bottom of hull this would equate to a x-dim of 20-13/16.
If he meant 1 inch above the bottom of the hull the x-dim wouild be 22-13/16
Kept the Bullet and the condo and joined the cig 20 restoration club.
Do a search this has been covered many times, I have one that is under the "Drives" section called "what is your drive height". I raised mine up 3" from stock, I think the x went from 15.25" to 18.25". All boats are different, too low too slow, too high and it will not plane off.
Single engine pleasure 28 Panteras need the X at 17" and thats even agressive. Any higher and its hard to carry the bow. You can go to about 17.5 or maybe 18 on a lighter race/poker run boat with no cabin.
