Need some serious help - Luke Chinewalker has boarded my Sunsation
Not having full hydraulic steering, aside from the safty issue, will hold the outdrive steady but will allow you to have play in your steering input. This means you will have to make larger corrections with the wheel to get the same result as full hydraulics. This makes it harder to drive the boat.
There is a reason they limit the engine size in the F1 boats ... there just isn't much hull in the water with any boat that size when you pass 80mph. Above 75+mph I actually trim my outdrive in a tiny bit which makes it substantially more stable. There has to be a balance between speed and driveability.
Originally posted by audacity
YES...and not very safe either.... do everything to ensure safty first!...speed is secondary.
is this used as a lake boat or an offshore?
joey
joey
-Mark
i agree with wilerty, the boat was just not designed to do what u want it to...doesn't mean u can't change that...good luck bro!
funny a lot of people are willing to change enignes and everything else....but never look a the bottom design or rigging.... i'm all about how well you go fast and not how fast you go. so hp is the VERY last thing on my list.
yes cg is something to look at....BUT look also at the cf in which the delta pad and drive have everything to do with....cg can be a bandaid for a incorrect or less than ideal cf....
joey
f2-80
joey
f2-80
