How to slow down
How to slow down
What is the best way to slow down from 60+mph when approaching a boat wake or some rough water? It is best to pull back on the throttle quickly? Or trim the drive down deeper into the water? Or put the trim tabs down? I would like to slow down quickly without putting extra strain the on boat/motor/drive. FYI, Boat is a 25ft I/O with 454 and Bravo 1. Thanks.
Its best slow down normally. Chopping the throttles and putting it back down is more strain than having to plan off again.
SORE MEMBER
1 Post
I always de-throttle and trim down at the same time. Not sure if the trim angle helps the braking, but I do it to have the correct position for getting back on the power.
When I'm running over 90 I back off the throttle slooooowly and start dropping drive back in but not too fast so boat doesn't bow steer , but at sane speeds I just pulll back the throttle and dig drive in,Smitty
I say just buy an Apache. Generally, I accelerate into oncoming bumps and only cut the throttle if props break the surface.
