Speed Waxes
Old 05-23-2002, 09:51 AM
CigDaze's Avatar
Originally posted by BajaBoss252
It takes some of the pounding out in rough water? That's like saying if I wax my car, it won't hurt as much if I hit a tree...
I'm not certain one way or another if this stuff really works, but whatever it is that these speed coatings do, they will work the same vertically as they do laterally in reducing drag.
It reduces drag to increase speed and will also reduce drag when re-entering, lessening the impact resistance of the water.
CigDaze is offline
Old 05-23-2002, 10:29 AM
Forum Regulator
Sydwayz's Avatar
Received 1,255 Likes on 548 Posts
Ok, I just watched the video for Hyspeedkote. It seems pretty straight forward, but the over-application part scares me a bit. I do not want an amber hull. My main question is this: If I am directing water toward my hull, and the Hyspeedkote is designed to soak up some H20, aren't I opening myself to blistering concerns, especially where my boat won't dry completely for a while, (where it sits on the bunks, on the trailer). I worry about this already, not to mention if I am attracting water to the hull as well, with Hyspeedkote. How does this act at a protectant/bottom paint, if I am bring water closer to my hull than before?
Sydwayz is offline
Old 05-23-2002, 11:03 AM
the koting works as a bottom paint also. as per the bottom looking amber that was four years ago when the first batch turned orange when it hit the sun. they have since fixed that.
Treadwell
Treadwellmotorsports is offline
Old 05-23-2002, 12:11 PM
Vern's Avatar
Treadwell, BruceK, and Audacity, thanks for taking the time to reply to my question. Sounds like it my be worth a try!
Vern is offline
Old 05-23-2002, 09:37 PM
velocity260's Avatar
dude you are a good sales man , just kidding if it will keep the green slime from the great lakes off I would go for it for sure.
velocity260 is offline
Old 05-23-2002, 10:02 PM
Tinkerer's Avatar
Cool
I used to use VC LIQUID SPEED - that stuff really worked -EPA made them stop making it - same as freon 11 +12
Tinkerer is offline
Old 05-24-2002, 07:01 AM
they are all out of $$$ mike!!!LOL
make sure to use alcohol to clean the bottom....u may get a slight tint of yellowing....so they say, or boats did not.
audacity is offline
Old 05-25-2002, 02:36 PM
baldguy215
Wink SpeedWax
I tell you Ausley's Wax works best. I have used it for 3 years and we have won 2 World Championships and 1 National Championship. F2-15 is fast and the secret is Ausley's Wax. If you want to be fast and injured wax your boat with Ausley's Wax, it makes it fast and damned near impossible to walk on the deck without a harness.... ask TJ.....
Old 05-25-2002, 06:41 PM
Tinkerer's Avatar
HIRELESS ONE -Where do you get it.
Tinkerer is offline
Old 07-22-2002, 12:15 PM
26scarab's Avatar
Just curious if anyone has any feedback on the Hyspeedkote ?
Thinking about trying it .
26scarab is offline
Quick Reply: Speed Waxes
