Doug's Insanely Cool Engine detailing trick >
Old 03-20-2011, 11:50 AM
Default Doug's Insanely Cool Engine detailing trick
DICE DICE baby!!
http://www.1017.org/nsx/Enginetrick/EngineTrick.htm
Catmando is offline
Old 03-20-2011, 12:00 PM
Originally Posted by Catmando
cool just have to worry about soaking down with water all the electrical connections & conponents
Old 03-20-2011, 01:57 PM
offshoredrillin's Avatar
Received 1,297 Likes on 449 Posts
Works better with WD40 instead of the tire cleaner, it will displace the water and no harm to the electronics ..
offshoredrillin is offline
Old 03-20-2011, 02:17 PM
Thanks I'll remember that when I start.
Catmando is offline
Old 03-20-2011, 02:25 PM
bobonthis's Avatar
I detail cars and thats an old trick. The problem with it, is that the cleaner gets on your belts and causes them to slip..therefore taking life out of your belts. The other problem is anything silicone base attracts dust and gunk. I would suggest just using the degreaser, unless you are showing the car. Oh and last thing..when spraying cleaner on the motor you tend to get overspray on the windows, fenders etc...and becomes more of a PTA to clean.
bobonthis is offline
Old 03-20-2011, 03:14 PM
never thought of that
Old 03-20-2011, 03:16 PM
Charter Member #394
SFOcean's Avatar
Or you couold use S100 Total Cycle Cleaner. Does not damage plastic, rubber or vinyl. Get it at a motorcycle dealer like HD.
SFOcean is offline
