KE Valve Covers CURE????
Eddie Young did my engines. He told me that it is a fact they leak. The milling of the rail takes care of this..... Not too difficult to do. Oil being flung up into the breather also happens. It also saturates the elements and doesn't let them breath, then you push oil out the dipstick. I installed breather tanks to cure this. Just stick with it and eliminate that mess. Unbelievable that it would be such a flawed design. Nothing worse than oil in the bilge.
I would turn the breathers the other way ..because your problem is most likeley that the front lifter on the left side ( looking at the picture ) and rear on the right side is throwing the oil right up the breather !
If they are new and not used ..THEY DONT LEAK on the o-ring !
I could give a chit who it is, KE-Lighting whoever, all I know is I paid $1000 for a pair of covers that out of a total re-rig and NEW POWER are the only things making a mess!!!! Problem at hand is I spent $$$$ for a product that does not work and on top of that has a NEGATIVE effect on my investment. And the reputable "KE" does not give 2 chits!!!!!!
I have been using the covers for years and unfortunately they leak. They have just recently started sending the rails out with a rubber gasket at the bottom of the rail. The cover sits on top of the gasket and should eliminate the leaking. I have milled all of the rails to the previous ones I used and it helps a ton. However, you can't mill the rails on the newer style bases.
Are these the new bases you have Nolan? I just used my first set of the new bases on the dyno and they did fine. I haven't run them in the boat, so we will see how that goes soon.
They also have a tendency to throw some oil out of the breather. It helps to open up the oil drainback holes in the head as large as you can. Obviously, you can't do it now with the engines together. Just something to keep in mind in the future. As Eric stated above, the breathers get soaked with oil and can't breathe anymore. Then the oil really comes out. A breather tank will stop that from happening.
Nolen, do you know where they are leaking from? Are they leaking from the base or the breathers?
Eddie
Eddie
Geronimo36
Seems to me I would just opt for a different brand valve cover. You got $1K in valve covers, oil tank and associated plumbing. At the end of the day you may find yourself with a $1500 set of valve covers.
Not sure about most people on the board but I turn my own wrenches and would rather take the extra time to loosen the manifolds/header to remove the cover, than waste my money like that. Then spend the $1200 savings on something else. Just my $.02, don't mean to offend.
![Smilie](/forums/images/smilies/smile.gif)
Eddie
Eddie
Not sure about most people on the board but I turn my own wrenches and would rather take the extra time to loosen the manifolds/header to remove the cover, than waste my money like that. Then spend the $1200 savings on something else. Just my $.02, don't mean to offend.![Smilie](/forums/images/smilies/smile.gif)
![Party Smiley 004](/forums/images/smilies/party-smiley-004.gif)
