Best Hull/Stains Cleaner! Easy to Use
#31
I did a google on ring-go and find it for urinial cleaners in what looks like a small bottle and then a different place has it under spa cleaners in a wild cherry thick liquid gallon container. Which is the right stuff or is it the same?
How much do you sell it for Vyper34? The link at the beginning of this thread didn't work for me...
Thanks!
Thanks!
#32
Try a product called Iron Out. It is available at many supermarkets and hardware stores. It's an old fashioned remedy for getting dark stains out of clothes and plumbing fixtures. Just mix the powder with hot water and wipe on, rinse off. It works really well on the yellow/brown hull stains. It does not work as well in the bilge unless a degreaser is used first.
#33
"The Best and Fastest Hull Cleaner" is Power One!
Not only the Best and The fastest Power One has No Smell! Try it you will see it out performs all the others.
WWW.POWER1ONE.COM
WWW.POWER1ONE.COM
#34
try the Leverage hull cleaner.. works extremely well with no acid or harsh chemicals. In the long run, the acid in many products works, but long term effects on the fiberglass is detrimental. If the pours are closed and cleaned with the proper product, and then sealed with the Leverage polish.. clean up is a breeze... everytime.
http://topnotchperformancemarine.com...oducts-c2.html
#35
Power One FAST WORKING ODOR FREE!
Demos' this weekend in Atlantic City of Power One at the www.power1one.com boat. Opa team Adreneline Rush Racing.
