Water Preesure HELP!
ok wasnt sure if you were taking water pressure at the hose or right off a port on the block. GOTCHA!
Sorry im new to the whole non drive water pickup stuff. Now im wishing i knew this last week! Just drop'd the motors back in.
What do you guys think about mounting the discharge port? Shoot them out the back or run them out the sides of the boat?
I ask because my thought is you can see if your blowing pressure if you mount on the side of the boat. There is no way to tell if its coming out of the arse end.
I had Bob Wallace at Offshore Performance (here in souht Jersey), replumb and replace both pressure relief valves.
The two outlets that you see one is for the bilge pump, and the other outlet is for the pressure relief valve. Twin engine boat, each side is plumbed identically (understandably).
