Oil Filter stuck Tried Everything! >
Old 04-08-2021, 06:13 PM
  #61
Giant Channel locks, Giant screwdriver driven through filter, Air chisel on filter base. In that order!
thirdchildhood is offline
Old 04-08-2021, 06:52 PM
  #62
dammmmm....
I had a fuel filter that was stuck on so bad it was destroying the mount. I ended up taking the whole mount off the engine so I could stick it in a vice. drove a 2' long screwdriver through it and breaker bar'd that F'r...
SabrToothSqrl is offline
Old 04-08-2021, 07:02 PM
  #63
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Your lucky. I had a couple oil filters (not mine) I’ve hade to take a chisel to the base at the pad. Always put oil on the rubber seal😎
1BIGJIM is offline
carnutsx2 (04-08-2021)
Old 04-08-2021, 07:43 PM
  #64
If you know a medic or a nurse, the blue rubber tourniquets wrapped around it then either hands or a filter wrench. The rubber makes a nonslip surface.
phragle is offline
Old 04-08-2021, 08:27 PM
  #65
seafordguy's Avatar
Those chain wrenches that are on vice grips are the solution. Cheap at harbor freight and will get them right off. I've final gotten smarter and never put a filter ON with a wrench. Just my hands
seafordguy is offline
CT River Baja (04-09-2021)
Old 04-08-2021, 08:34 PM
  #66
Hammer and chisel, in lip on base of filter.
2john is offline
The following 3 users liked this post by 2john:
carnutsx2 (05-10-2021), CT River Baja (04-09-2021), tmdog (04-11-2021)
Old 04-08-2021, 09:27 PM
  #67
OldSchool's Avatar
I haven't used a wrench to put a filter on.....EVER!!! And I always put oil on the gasket. I don't know why this thing was stuck....but it was stuck like a MoFo!!!!
OldSchool is offline
Old 04-09-2021, 08:01 AM
  #68
Sometimes I can't get my hand on a filter good enough to trust tightening it by hand so I have to snug it a bit with a filter wrench. A bit too tight is infinitely better than having it come loose!
Old 05-10-2021, 03:31 PM
  #69
Default Heat it up
I have a heat gun that is supper hot. I’m sure that would loosened up the oil filter. On my aircraft I use dow 40 in a green tube. It is a clear silicone used on the rubber gasket.
turboeddie is offline
Old 05-10-2021, 06:46 PM
  #70
PigNaPoke's Avatar
try cracking them loose before you drain the oil. not enough to leak just loose... then warm and drain...
PigNaPoke is offline
