Ilmor Marine MV8 6.2L?
Ilmor is an engine company that does not put its talent or name on any engine that is not exceptional and a first rate reliable product ,Period!
This engine series should be a great small block replacement engine with a great weight to horsepower ration and excellent overall power and torque.
The real issue here for re-power is whether Ilmor will release these engines without the catalyst emissions systems for re-power on older hulls only as the emissions engine package cannot be modified with headers or otherwise for non-emissions use.
There is no reason you could not use the emissions version though but the engine would be basically unmodifiable because of the special ECM and programming.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
CMI headers
Darrell,
Actually CMI does offer a variety of LS Small Block headers, short and long primary versions.
CMI
CMI
What is the weight saving of a n Alpha over a Bravo? The reason I ask is, a 400 HP LS motor, mated to a bravo style drive would be almost an indestructible package, with only a small increase in overall weight. I personally would give up a few pounds of weight to have the added durability. Just something to think about.
BTW, the CMI headers are designed for the old small blocks. The lLS style motors have a different port spacing. I'm not sure if they have them for LS motors yet.
Darrell.
Darrell.
What's a marine emissions engine???
Maybe I should explain further for those who don't understand the new EPA required MARINE EMISSIONS ENGINES!!.
These engines even the one talked about here by Ilmor use a catalyst system in the exhaust manifolds which is controlled by this engines ECM. If you take off this system and add headers, -"THE ENGINE WON'T RUN!!" They have special O2 sensors and inputs from the catalyst and fuel systems to calibrate them for emissions and unbolting this sensor system will not allow the ECM to run the engine. New headers currently don' t have catalytic converters in them.
The manufacturers like Ilmor won't re-program the ECM or allow any other party to re-program the ECM to eliminate the catalytic system as that is a violation of federal law and would result in their loss of approval to build these engines period!
The days of just un-bolt the old and bolt on the new with respect to new (2010 and up) marine engines is gone except for two manufacturers may still produce these type of engines for re-power in older boats only as various states may allow!
Not trying to RAIN on anyone here just trying to get performance boaters educated in what the new emissions engines are and how they are currently and practically unmodifiable so they don't go purchase one, buy headers and find out after the fact what they might be stuck with!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Were doomed!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
I wonder if you can adapt some O2 simulators like you can for the LS based cars that get heavily modded???
-Wally
-Wally
Thx ! I hope so ,it's a 21 v hull bare hull weight arround 1100 lbs and gonna try a blackhawk on it hoping to be touching the triple digits if I have the balls to get it there ,normally they are outboard hulls doing 78 mph whit a merc 280 efi
Were doomed!
And i have made them myself once to pass emissions on my truck when i had a bad connector and procrastinated too long before getting it fixed and had to go get my emissions done to renew my plates!
-Wally
-Wally
