Where ARE all the LSx motors hiding??? >
Old 11-04-2012, 08:03 AM
  #201
JIMKID Motorsports's Avatar
Check out the post about ilmors small block ls based test boat
JIMKID Motorsports is offline
Old 11-04-2012, 09:11 AM
  #202
bor
bor's Avatar
do you have a link ?
bor is offline
Old 11-04-2012, 10:54 AM
  #203
http://www.offshoreonly.com/forums/g...id-2013-a.html
4mulafastech is offline
Old 11-21-2012, 09:45 AM
  #204
Damn, looks like Raylar was right.....not so much.
Precision is offline
Old 11-29-2012, 08:01 PM
  #205
Originally Posted by timmoore
What he said...
I was afraid to post anything until I saw how it ran.
Adding more power to it this winter.
Are you using MAFs?
hogie roll is offline
Old 11-29-2012, 08:31 PM
  #206
Originally Posted by Michael1
I am not sure what you mean, by "not hurt anything". Life goes down when load goes up.
I can't think of one reason why this would be the case, unless there is so much load on the front crank bearing of a supercharged engine that it is wearing it out.
Michael
My auto turbo motors have lasted longer (tune being correct on both supercharged and turbo). I could feel the harmonics of the supercharger, belt etc in the floor of the car. It just seemed harsh. As for wearing bearings out. I have had issues with the front crank bearing having excess wear due to having to tighten the blower belt so tight to keep from slipping under boost (serpentine belt not cog). I actually had a crank snout break off going down the interstate under full boost one time. My turbo motors (turboed small block fords) were so much smoother in comparison and power delivery was just awesome compared to the supercharges I had ran before. I changed setups and went from twins to a single. While doing so I torn the engine apart to freshen things up after 20k miles and everything seemed great (680hp to the wheels). Virtually no bearing wear like I had experienced from the supercharges.
cp5899 is offline
Old 11-30-2012, 07:22 AM
  #207
Originally Posted by korvetkeith
Are you using MAFs?
Yes. I did run it the first couple time without them though.
timmoore is offline
Old 11-30-2012, 07:32 AM
  #208
I'm seriously considering it thanks to sprink. Been doing a lot of research.
Lkqonline.com good place to start. Complete motors 6.0 in te 1000 dollar range. High mileage but a good base point if your interested.
Crude Intentions is offline
Old 12-01-2012, 06:52 PM
  #209
I've been under the impression that heated wire MAFs are a fire hazard and not generally compliant with marine standards. I don't know how risky it actually is though. Any concerns? I see your hatches are pretty well vented.
Old 12-02-2012, 01:45 PM
  #210
Diamond Member #001
C_Spray's Avatar
LS-based engines currently in full production:
Crusader 6.0/375 hp inboard
Ilmor 6.0/382 hp inboard
Ilmor 6.2/430 hp inboard
Ilmor 7.4/522 hp inboard (Basis of the upcoming 570.)
PleasureCraft 6.0/409 hp inboard
PleasureCraft 6.0/450 hp inboard
PleasureCraft 6.2/550 hp inboard(supercharged)
Volvo Penta 6.0/380 hp sterndrive
Of all these, the Ilmor 7.4/522 is the only LS-X engine.
Crusader still lists 8.1 (496) engines on its web site. Volvo Penta does not, but is the only company to offer a sterndrive LS package so far.
C_Spray is offline
