Ilmor High-Performance unveils MV8 570 Small Block
#141
#142
OK, I'm going to stick a foot in my mouth again and am sure I will get slammed for it but first I want to clarify a few things. I fully admit to not being a professional engine builder by any means, however, I was an automotive machinist/engine builder for about 15 years. Granted 90% of the work we did was stock rebuild stuff for cars and trucks but we also built some custom and high performance stuff as well (granted no 15,000-30,000 motors or else I would still be doing it, I am sure my 50% commision checks would have been much better if we did). Also I admit I have never dyno'd or witnessed a dyno using wet exhaust so if one of the professionals can show me that you lose 20% on the dyno with wet versus dry exhaust I will gladly retract my claims. I would also like to state that when I state I am not impressed with a manufacturers results I am by no means insinuating that for some reasons there motors are junk, or that they do not know what they are doing. Having said that I will once again state that I am very pleased Ilmor is coming to market with an LS based marine motor. It is something I have always said I would do if I had the resources. That said I am still not impressed with their results. Don't get me wrong (Ray), the motor may be bad ***, it may be able to idle around the docks at 600 rpms all day and go 1000 hours before a rebuild. The parts and quality may be second to none. I am just not impressed with the final numbers. I feel they are still leaving a lot on the table. I wish we knew a little more about their build. There use of GM head castings has me scratching my head a bit. Did they use the new LS3 heads or the old style cathedral heads, were they CNC ported or out of the box? I would just expect with their vast resources and engineering knowledge that their 454 LSX would make better numbers. Before bashing me consider the latest article in GM High Tech, They took a budget 408 (cast iron 6.0 truck block bored .030, 4.0 inch stroke, 10.0 compression, etc.) and made several dyno comparisons using a pair of aftermarket cathedral heads and a pair of aftermarket square port heads along with 2 off the shelf Comp cams and every combo made over 630 HP and over 575 ft/lbs tq. It just seems to me that a company with the resources and knowledge base that Ilmor has would be able to trump these results. That is unless their goal was just a super docile long lasting big inch small block which I am sure this will far exceed those expectations.
Pretty sure you mean this 408. Right? Same build from the article you quote.
Notice the headers- dry and super large with a nice long collector.
Not a wet marine header.
Notice the accessories - or lack thereof.
No seapump
No recirculating pump
No alternator
No power steering
No Ignition (ignition is supplied by the dyno and powered externally - usually)
Im actually a bit surprised it didnt really make any more torque than my 406 small block.
It also has an endless supply of fairly cool water.
It was dyno'd using 93 Octane gas (you cannot find that in any marina)
By the time you add all of these things together the effect it would have on that 408 would be dazzling, and I doubt it would put out near what the Ilmor does with all of the above hooked up and running. Then it has to idle in and out of gear, and not revert water...
and then theres the warranty..........
Uncle Dave
#143
I know I am gonna take some real flack over this post, but here it goes!
It seems as though we always seem to have this automotive magazine and automotive high performance representations and comparisons on how much horsepower and torque LS engines can and do make? Lets face it in high performance automotive use and even race car usage LS engines in various sizes, build types and configurations can make anywhere between 350HP and 2000hp. This has been done demonstrated and verified probably over a 1000 times in the US alone in the last 4-5 years alone. No one hear is arguing or saying that the LS based engines are not great engines, no one is saying they can't make awesome horsepower, no one is saying that they are not a good PLATFORM for marine usage and I am not saying they will make 20% less power because of wet exhaust usage!
What I and others here on OSO are saying who have good marine engine knowledge and some good LS engine development experience is that when you take an LS or LSX based engine even with the best reworked GM or aftermarket heads, put in camshafts (that will work in wet exhausts in boats)and marine header systems, use cubic inch sizes of lets say 427 to 454 and set them up to idle at lets say 650-750 rpms (for drive life) without any reversion, keep them in an rpm limit of lets say 6200rpms, ask them to make high torque from lets say 2500 rpms to 5500rpms, install and run all the accessories needed such as raw water pump, circulating water pump, power steering pump, alternator and complete serpentine belt drive system with tensioner, use a complete freshwater (heat exchanger) cooling system to protect all aluminum parts (heads especially), use heavy flywheel and coupler, build them to run under high loads for many hundreds of hours in boats, warranty them for a minimum of one year maybe more and have them meet current EPA, Carb and European emmissions standards with catalyst exhaust control systems -YOUR HORSEPOWER DEVELOPMENT WILL BE ABOUT BETWEEN 500 AND 600hp AT BEST! These puppies complete will cost the boat buyer about $25-$35K depending on whose offering we are talking about. You ain't gonna buy one of these LS or LSX high performance full marine engines for $10-20$K that will do all these things.
I guess what I am saying here is I am just about sick and tired of the constant comparison of performance automotive use and performance of LS & LSX based engines with real working marine LS & LSX engines-THEY AIN'T THE SAME ! and this type of constant comparison will only misguide and misinform potential marine engine interested and serious buyers or users who are not well versed or familiar with LS & LSX marine engine offerings and what it takes to get these engines in marine high performance endurance trim.
This thread was started to discuss the new Ilmor MV570 LSX marine engine, which is just such an engine and produces results right inline with my statements above. Ilmor has done a magnificent job of bringing a complete, well engineered and constructed LSX marine engine to market that I am sure will perform beautifully in correct marine applications and will give years of trouble free performance and reliability just as their V-10 marine engines have done. Ilmor does not put their name on mediocere marine engine offerings!
For any others out there who can deliver such a product or viable offering then I say BRING IT ON! it will be well received and if you can exceed these ranges for reliable power and torque it will be even more well received.
Jim has built some nice LS marine engines and if they can be put into production and deliver on these requirements then great, he should get busy and put them to market! He as well as anyone should also be prepared to prove up their performance and reliability.
I know there are nearly no marine performance magazines now for readers but lets stop this automotive performance substitution and comparisons especially from magazine sources- it's really is getting old and it reads like BAD BENCH RACING where people are comparing apples to tomatoes! they are both fruit, but that's where the comparison stops!
As for this developing fray between JimKid and Skater 30 it seems like the only real finality other than their inflamatory tossing tennis match thats going on may be some sort of special SHOOTOUT that might be arrainged in Michigan this year that should be convienent to both parties. What's that other old saying "When the green light drops, the bull**** stops" Should get a big attendance from OSO'ers and interested performance boaters AND BE THE TOPIC FOR A LOT OF FUTURE DISCUSSIONS!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#144
No seapump
No alternator
No power steering
By the time you add all of these things together the effect it would have on that 408 would be dazzling, and I doubt it would put out what the Ilmor does with all of the above hooked up and running. Then it has to idle in and out of gear, and not revert water...
Uncle Dave
No seapump
No alternator
No power steering
Uncle Dave
#145
Fair questions. I believe based on its history Ilmor could make an engine from scratch do do whatever they wished with one exception. Hit a price point.
When I spoke with one of Californias most highly regarded engine builders about accessories and header loss on his marine engines compared to a raw dyno the number floated out was around 100 on a 500 HP engine. This guy has an in house dyno and more than enough data to back his claim, and is one of the few builders that can deal with my Mercury product and my Ilmor product. (that'll narrow it down greatly)
When I said the difference all that stuff makes is dazzling I wasnt being overly dramatic.
Ray is right on the money - you cant compare a block bolted to a stand with one ready to run for the marine application.
This is why there arent 10 guys doing it right now.
If we reverse this the comparison and say the Ilmor under the same conditions puts out about 670 HP (and has a warranty and actually idles AND passes CARB) would you feel better about Ilmors LSX representation to the enthusiast?
Uncle Dave
Uncle Dave
#146
I know Ray gets passionate about these discussions and he has most likely forgotten more about marine engines than most of us will ever know so I respect his opinions but I still think that Ilmor has left a little on the table when it comes to their LS marine power plants. Who knows, maybe that is all in their plan. Start out conservative and then tweak and improve as they gain experience. Is that not how they started with their V-10 program. Remember it started out at 550 HP, then they made modifications and improvements and before you know it they are up to 700+ HP. I am also not so quick to disregard automotive technology. Granted I have nothing to compare to most of the HP mils on this forum, but my 355 ci small block was built by an automotive machine shop back in 1995 with all automotive spec off the shelf parts and made 425 HP and 450 ft/lbs of tq and now has almost 400 hours on it since the build and has never had a mechanical issue (now the factory 1987 EFI system and electronics are another story).
#147
#148
Uncle Dave
Uncle Dave
#149
On 91 octane a GM LSX 454 with a cam swap made 628hp and 604ft/lbs running wet aluminum manifolds and all accessories. Sure Ilmor's engine could make more power but that can be said of anything. I can give you an extra 40+hp on almost any LS powered vehicle by hitting a few buttons on my Keyboard with HP Tuners. Did GM let you down? No, they built it conservatively, just like Ilmor.
#150
ABSOLUTELY... If that is an accurate number it would explain everything. That was why I questioned if it made a 20% difference (which is exactly what a 100 hp would be on a 500 hp motor), but even Ray said it would not make that much difference. Was he comparing car headers to wet high perf marine headers or stock Merc style manifolds?
Its all the stuff on top of the exhaust he and I both came up witha similar list of "stuff".
Every driven device carries a HP penalty.
Ray could probably tell you off the top off his head about what each driven accessory "cost" The recirculation pump itself is about 14 HP. The alternator varies based on load- but its pretty safe to assume a boat is in charge mode quite a bit.
The exhaust isnt cut and dried either.
Oh....the marine exhaust may dyno only say 30 HP down- but that isnt in the boat yet.
If the pipes go straight out it will probably put out the same power on the dyno - but if your installation requires you to put and "s" bend into it- look at losing 10-20 more.
All that stuffs add up really quickly.
UD
