Boat Lifts with Stepped Hulls
Bunks
[QUOTE=tomahdonzi;3656174]Maybe there is a thread out here on this topic, but I did not find it. I have a Donzi 27ZR with stepped hull (2 steps). I am thinking about purchasing a boat lift. Probably a Shorestation. My question relates to the bunks on the lift. On my boat trailer, the bunks are stepped to match the hull. This way no weight is being put at the point of the steps. I would assume that I would have to have a similar setup on my lift.
Any thoughts on this?
You could speak to your trailer manufacturer. Example, MYCO, who made my trailer, would fabricate a deck for your lift matching your hull just like the trailer.
Fearless010
Peter
Fearless010
Peter
Ginger or Mary Ann?
Your boat still weighs the same no matter what it is sitting on. Now if you want to put that weight on the edge of your step, go right ahead. Or you can evenly support the hull. Thats the common sense. There's a boat on a lift down from me that is sitting on an edge that the hull is pushed up a good inch. I'll grab a pic this weekend. But it's not my boat. So I could care less
Registered User
Boat Lift with Stepped Hulls
Guys,
Thanks for the comments. I agree that I should match up the bunks with the steps on the boat, just like I do with the trailer. These big lifts now use aluminum bunks with carpeted wood bolted to them. So on the big lifts, I don't think you will see any flex in the bunks, and thus putting a fair amount of pressure on the steps, which I don't think is a good idea. I like the idea of just adding some carpeted wood as we move toward the back of the bunks, to match up to the hull (and I agree that you have to be careful to get the lift down enough so the front hull does not hit those higher bunks in the back). I also like the idea of maybe moving the bunks in quite a bit so they miss the steps. That's something worth looking at too.
Thanks again. I have the engineers at Shorestation looking into this as well. Will be interesting to see what they say.
Myco does manufacture and sell racks that fit the bottom of your boat for use on a lift.
you can also cut the steps into the bunks to match the bottom of your boat like we did, see pics. pics are before we added carpeting obviously.
Registered User
ktron,
Thanks for the myco info. That looks like the way to go. Now I'll just have to look a little closer at the proper Shorestation lift to see how they mount the bunks (they use aluminum bunks with wood over them, so maybe we just eliminate the aluminum and go with this set up).
Thanks.
Thanks.
We have a slip available for the 2012 Summer Season that includes a boat lift. The lift will accommodate a boat up to 29' for $100/ft~!!
www.bordenlightmarina.com
www.thetipsyseagull.com
Give us a call~!!!
508-678-7547
Give us a call~!!!
508-678-7547
All the decent lift makers at LOTO place extra boards in to fit the steps. They leave about 6-8 inches of play when sizing the boards so that you have a little leeway on exactly where your boat sits on the bunks, and it will still give proper support. Also make sure your lift drops low enough that your steps clear the extra boards when backing off so the boat doesn't get hung up. At LOTO they set depth with chains so you just need to lower the chains a couple links.
Ginger or Mary Ann?
Depends if the lift is a back in model or not. If back in, not a problem.
