ethanol free gas stations
i also saw a station here in Rochester NY that sells 89 non ethanol, what i can figure out is why these 2 gas stations i found are about 40-50 cents a gallon up charge for the the non ethanol fuel VS the 10% ethanol fuel they also sell??????
Anyway heres the tester i bought, search with the part# and you can find it cheaper at another place but this was the first link i found to it to show you guys.
you simply fill it with a certain amount of water, fill to the line with gas, shake it up real good then little it settle. if it has ethanol it will absorb the water and move the separation line up on the vile to show the percentage. if theres no ethanol present the separation line will go right back to where it was before you shook it up.
http://www.lawnmowerpros.com/detail.asp?id=795161
Forum Regulator
Thank you for bringing this back up. The list had drastically expanded since the last time I checked a year or so ago.
Generally, marinas have ethanol free gas. Where you are in WV I might check at the Raleigh County Memorial Airport. Might ask the golf course or some of the mining companies if they use ethanol free and if so where they acquire it. If there is a wholesale fuel distributor in the area that can be another research source.
I have heard it called different things like off road gas and sport 90, but I am fairly sure it is all the same. I forget where I was, but a dealer for snow machines and ATVs had a pump in the service area (outside) and it was the ethanol free fuel.
I don't even want to get into or start the debate about ethanol removal additives.
