Is Toilet bowl cleaner ok for cleaning hull >
Old 06-27-2002, 04:32 PM
Von Bongo's Avatar
I use Zep TB cleaner and dilute it 50/50. works good on the nasty Mo river lake scum. I pu tit in a weed sprayer, spray on the solution, let it set a minute or 2 and wash it off
Von Bongo is offline
Old 06-27-2002, 06:34 PM
CBPBA's Walmart Greeter
Keith's Avatar
I've used both the toilet bowl cleaners and hull cleaners. The Toilet cleaners cling, go on better with a sponge or brush, but I'm on a boat lift so I have to use a chem/garden sprayer. Economically On/Off is the way to go. I buy a gallon of On/Off Hull cleaner and cut it 1 part On/Off to 5 parts water. Might need to buy 2 gallons a year at the most.
Wax only keeps it from yellowing for a couple weeks, eventually the hull yellows, and I've tried every brand & type wax you can come up with over the last 13 seasons, 2 coats of Liquid Glass applied as instructed on the can is the only thing that lasted for almost 8 weekends. Everything else failed earlier.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 06-27-2002, 07:44 PM
Toxic FORMULA
mopower's Avatar
I've been using Greased Lightning wheel cleaner,not degeaser, but wheel cleaner. Two dunks in the Delaware on the weekend and I have a yellow bottom(the boat that is). This contains oxolic (sp?) acid.in a weak concentration. Start at the front and by the time you reach the back you can rinse it off front to back and it's snow white.Soaps , cleaners and compounds I've tried wont touch it. Get mine at K Mart in the auto section. Been using it a few years now and no signs of any problem
mopower is offline
Old 06-28-2002, 05:06 AM
MIdnightRider
I think I may try that wheel cleaner. I have yet to find something other muratic that takes the brown-yellow right off, But that stuff is strong. Someone has also suggested CLR, I am buying that this week too. My headers dump on the swim platform and it's a pain in the ass to keep clean. Not to mention what happens to the hull. I have noticed that it does seem abnormally bad in our area this year(the scum- no offense pocket change. ). Midnight
Old 06-28-2002, 06:38 AM
nautigirl's Avatar
We used Soft Scrub w/ bleach on our old boat - the white part obviously. Worked like a charm!!
nautigirl is offline
Old 06-28-2002, 08:25 AM
I can't remember the name, but its the scrupping bubbles one it worked
boomer is offline
Old 06-28-2002, 08:43 AM
Luv-N-It's Avatar
I use Soft Scrub w/Bleach on white hulls. Works great. Put wax on after using Soft Scrub too. I have also used Soft Scrub w/Bleach on the hull @ the thru-hull exhast. Works great getting the exhaust build up off there too. Again, wax the area after you use Soft Scrub.
Great posts everyone, keep'em coming. Like the advice of other things to try. I might try The Works, see what it does too.
Luv-N-It is offline
Old 06-28-2002, 03:40 PM
cuda's Avatar
I used to boat a lot in the Suwannee River, and that river is so tannin stained that one day in the water will turn a hull brown to the water line. Everyone up there uses sno bowl, I did too.
cuda is offline
Old 05-12-2013, 09:30 PM
I've used sno bowl with great success before. But where do you get it? I bought some generic brand bowl cleaner and it didn't touch what ever is on this new to me boat. Are they not all the same?
hogie roll is offline
Old 05-12-2013, 09:39 PM
Default fixx
ummmm 11/12 year old post,,sno bowl most likely went down the bubes like every other biz since all mighty took over..
FIXX is offline
Quick Reply: Is Toilet bowl cleaner ok for cleaning hull
