Diesel-Powered 52-foot Outerlimits Hits 94 mph
#32
So does a 90* V8 with a 90* crank.
I hate to say it, but this inline-6 is better than V8 is urban legend. I spoke to a Cummins engineer once, and asked him about why they use I6's instead of V8's. His response was "packaging", and slight cost reduction. There have been V8 diesel marine engines over the years by Catapillar, Cummins, and others, that ran just fine.
Michael
Michael
http://en.wikipedia.org/wiki/Straight-six_engine
and have them remove this :
"An inline six engine is in perfect primary and secondary mechanical balance, without the use of a balance shaft. The engine is in primary couple balance because the front and rear trio of cylinders are mirror images, and the pistons move in pairs. That is, piston #1 mirrors #6, #2 mirrors #5, and #3 mirrors #4, largely eliminating the polar rocking motion that would otherwise result. Secondary imbalance is avoided because the crankshaft has six crank throws arranged in three planes offset at 120°. The result is that the secondary forces that are caused by differences from purely sinusoidal motion sum to zero.
An inline four cylinder or V6 engine without a balance shaft will experience secondary dynamic imbalance, resulting in engine vibration. As a general rule, the forces arising from any dynamic imbalance increase as the square of the engine speed — for example, if the speed doubles, vibration will increase by a factor of four. In contrast, inline six engines have no primary or secondary imbalances, and with carefully designed crankshaft vibration dampers to absorb torsional vibration, will run more smoothly at the same crankshaft speed (rpm). This characteristic has made the straight-six popular in some European sports-luxury cars, where smooth high-speed performance is very desirable. As engine reciprocating forces increase with the cube of piston bore, straight-six is a preferred configuration for large truck engines.[6]"
and put your V8 there instead ,with its two banks of 4 cylinders !!!! The V12 which are a pair of 6s connected at the crank are not good as well in your head.
BTW The Cummins Indy car was a straight 6 Also.
#33
That was a great read! Thanks!
V8 ??? Do not make me laugh,Here you and your so called Cummins Engineer correct this then:
#34
#35
Pairs of 4 bangers in a vee , then you need ; Cross plane cranks with the heavy counterweights and or external balance , No thanks , Not even in my truck , got rid of the last V8 diesel years ago , These inline 6’s do just fine even on very large Cats I am bidding now, plus they fit well !!
#36
After that move on to power pulses per crank revolution.
Michael
#37
Steve, I think you have now officially lost your mind. Keith and I are trying to explain V8 engine balance to you. Since you won't listen people who actually have designed engines for a living, then finish reading the chapter on engine balance on your own where they discuss cylinder counts above 6.
Michael
Michael
BTW Mikey1, I design and build Boats that these motors have to power, That said I have been thinking about a 38 foot inline 6 Boat with 2JZ Engines .
Let’s see firing in a V8 Cheby Crossplane ; 1 = L , 8 = R , 4 = R , 3 = L , 6 = R , 5 = L , 7 = L , 2 = R
Firing LRRLRLLR Banks , there is your sound now ,a flat plane like a Ferrari they alternate banks.
Mikey1, I have the solution to your power pulse Problem , How about a V8 Two stroke diesel ??
#38
NO, YOU Lost your mind !! Coming in with this crap AND Miss my point by a Damn Grand Canyon ! OL I am very sorry about this drift OFF Topic here , That beautiful Boat you built and this plunge into V8's for some nonsense.
#39
Correspondent
Correspondent
So you think that the flat crank Ferrari engine is "balanced", while the 90* Chevy engine is not based on the firing order? Oh, boy.
"V8 Two stroke diesel" Already been done. Detroit Diesel 8V71.
I don't know much about designing and building boats. I'm not trained in it, and I never had a career in it. However, at least, I don't pretend to be an expert in it, and I don't get in arguments with people who's expertise is in that area. If someone wants to close their mind to someone with expertise, then it is their loss.
Michael
