bravo 1 to xr lower.
I have a question. Will a bravo xr lower bolt up to a bravo 1 upper. The only reason I ask is I have a set that I can install if it will work.
If it does work are there any mods that need to be made and will my 23 mirage plus props work.
Thanks in advance
Thanks in advance
Offshoreonly Advertiser
How old is the upper? Unless it is one without the oil passage is no problem. You will have to change to the XR prop hubs.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
im not sure about the prop thou,when i switched lower i also went to a 5 blade prop and needed diffrent spacer.I forget if it was because of the prop or the new lower.
mark
mark
