Outer Limits SV 29
Old 05-28-2012, 10:41 PM
OSO Content Provider
Commercial Member
SHARKEY-IMAGES's Avatar
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 05-29-2012, 06:51 AM
Originally Posted by noli
Wow never thought of how the deck played a part in speed.
Just as important as the setup below the water line
The scoops are good size but will not generate positive bilge pressure at speed. The engine will take the first 1100 cubic feet per minute. The vent in the back of the hatch is most probably in a negative pressure area and will bleed off any pressure.
Steve
smiklos@sunprint is offline
Old 05-29-2012, 08:45 AM
This is the nicest v bottom boat I've seen!! It just looks fast sitting there on the stands. The only negitve is that I'm sure the price tag will match is awesome looks, but I'm still curious. Anyone seen pics of the cabin?
cp5899 is offline
Old 05-29-2012, 09:37 AM
Knot 4 Me's Avatar
Originally Posted by smiklos@sunprint
I would not underestimate the aerodynamic advantage this and other later OL boats have. I can tell you in our SVL at 90 MPH 78% of our thrust goes to water drag and 22% to wind drag. As you reduce the wind drag the speed does not increase at the rate the numbers would imply because the water drag is greater.
It is very important to have a good aero design to get max results not just for wind drag but also for where and how much wind drag creates pressure (weight at speed) on the hull.
Steve
That was my thought too after seeing the boat in person at LOTO. This thing is a sleek, little bullet and aero has to play a big part in its performance.
Knot 4 Me is offline
Old 05-29-2012, 10:00 AM
socalstone's Avatar
Originally Posted by Cat & Mice
....The ecu was handed to us from Merc with the latest cal and that was the ecu that was in the boat....
I hope that is true.
socalstone is offline
Old 05-29-2012, 10:01 AM
socalstone's Avatar
What is the dead rise? looks less than 24º?
Old 05-29-2012, 08:46 PM
Default OuterLimits SV29 - Hull Layup Analysis
The hull and hull pieces are built from epoxy, E-glass, and carbon fiber...and are sent into an autoclave at 150 degrees for 18 hours.
Then the hull, and hull pieces are chemically bonded using proprietary adhesives. Once glued, the entire structure goes back into the autoclave at 150 degrees for 18 hours again.
From mold to out-the-door in just 3 weeks with the above process
WOW!
This is bleeding edge technology!
No wonder there are patents to this layup schedule.
For the complete article, please get your copy of this awesome magazine!
The following data compiled from:
SPORTBOAT Magazine
Your Power & Performance Source
Edition: Summer 2012
Pages: 30, 32
noli is offline
Old 05-29-2012, 10:01 PM
Originally Posted by phragle
lots of unobtainium, a little billet unbreakium and I heard from a secret inside source who wishes to remain anonymous that they are adding a few grams of unflipium to the unbreakium alloy.
Freekin hysterical I love it
frankenstein is offline
Old 05-29-2012, 10:08 PM
Question Funny car bodies?
I believe I heard OlL is also building hi-tech funny car bodies for some big name drag racing teams and the money and experience there makes for some good "ruboff" into their hull building science.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 05-29-2012, 10:45 PM
buck183's Avatar
Ditto this. I've seen multiple pics of two of these boats but have yet to see one pic of the cabin on either. I would like to see how it's layed out.
Buck.
buck183 is offline
