Is this speed for real?
#31
If the water conditions were absolutely perfect, you were running like 2/5ths a tank of gas and there was one-two people in the boat max, you could probably achieve that..
Other than that, I would guess the boat runnings high 90's low 100's on a good day with full capacity.
BUT FOR HOW LONG?! That is the question...
![Evil](/forums/images/smilies/evilB.gif)
#32
It has Stage 3 Whipples on it ....I believe...
and Liquidator ran 94+ with fuel, Older hull.. I've seen 98-100...trimmed to the moon and few miles to get her going...not much torque on the 510s...she still ran like an animal in rough water...fantastic big water boat...
Scott, you also were in the boat when I tested the new herrings when it ran 95...so what is your point?
Bad tach lead on the starboard motor...
#34
#36
A 42 epoxy with 1075s will run 125-130 depending on setup, props, etc. 116 is doable with a stage 3 whippled 700 boat. The nxt are lighter too. Just my .02, sweet boat by the way.
