Nothing ever goes right!!!!!! Transom assembly doesn't fit!!!
Gone Fishin'
Borrowed an electric grinder and bit from Tinkerboater. Thanks a lot Steve!!!!!
I'll post when I've got it done and on the boat. Till then, don't call, don't email, don't PM, don't IM, etc.... I'M BUSY!!!!!!!!!!
Official OSO boat whore
If you are really using a grinding wheel, you'll need a special one for aluminum. The regular steel wheels will quickly load up. Of course you're not doing much so it might not matter...
I would double check before I started drilling. I would guess the fitting on the drive will work like a one way valve letting water in when the drive cools off.
You may be better off taking out the valve and plugging the hole.
Gone Fishin'
RickR, I'm grinding on the INNER plate, not the outer. So, no water issues or leaks of any kind. I understand the one way valve on the drive/bell housing. No sweat!! But thanks for the concern.
![Smilie](/forums/images/smilies/smile.gif)
Like formula 31 said just spray WD-40 on what you are grinding (about every 10 seconds of grinding) and it won't load up as fast with aluminum. Hell MIKE if you had told me you just needed a hole I have bits all the way up to 6 inches. And the drill to turn it.
3/4 inch hole in 1/2 inch aluminum takes about 1 minute.
Gone Fishin'
Steve, I'm done grinding. Need help putting it on the boat.
Gone Fishin'
Thanks Steve. I should be home around 4:00 or so.
Charter Member #232
Cool deal Foul get your azz back out on the water!!! Hey you have the alignment tool right!!! ![Big Grin](/forums/images/smilies/biggrin.gif)
Put your best foot forward!
