Cockpit Padding
Yes, its closed cell. Just find a gym distributor and buy a roll of pilates mat. I put 5/8 under mine and used automotive emblem adhesive to glue it to the bottom of my custom carpet. Flip it and razor blade the excess. Done. Been under mine for 2-3 years.
LOL - Coincidentally, I got in a Hustler at the Miami boat show and couldn't get it out of my head.
You will seriously get off your boat after a day on the water and feel 10 times better. Its a BIG difference.
They come out and scan your boat with a $15,000 surveying machine that makes a perfect CAD file of the boat and then cut the pads on a CNC router. I had it done by a company called Castaways Customs. Its not cheap but it comes out awesome.
Probably helps that you`re in FloriDUHHH, all the marine stuff is down there .. looks amazing thou
He will come to you if the job is big enough
Tyler Shealey
321-537-2039
www.castawaycustoms.com
Castaway Customs Facebook
[email protected]
If not you can order template kits from Sea Dek and make your own templates its not that hard.
http://www.seadek.com/c-9-template-kits.aspx
Tyler Shealey
321-537-2039
[email protected]
My buddy has it in his OL. Call the foam factory. Closed cell 1.5" cost him right around a hundred bucks. Cuts it to fit and lays the snap in carpet over it. It is soooo nice on a long run or pokerrun.
JC Performance Engines
Contact Foam and More, they are local to you.
http://foamforyou.com/
They just made me some "MiniCell" wedges to use as footrests.
