Who sells the good hull cleaner?
OSO Moderator
I too have some Bon Ami in my cleaner's kit.
That stuff is like real fine Comet!!! It does leave fine scratches which dulls the shine.
I use Bon Ami for my non skid, it works good with a stiff bristle brush.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Yes, it did for me. I had some yellowing across the bottom and up the sides to the water line. Ringo worked like magic. I have never seen a product so easy to use that works. Just wipe on and spray off. Done!
I will say that you may want to reapply wax after using it. My sides were freshly waxed before using it. I did notice that the water did not bead up quite as nicely where the Ringo had been applied. I just got around to rewaxing the sides and hull last Sunday. After two weeks of post Ringo use......no yellowing!!
Seriously, I have tried everything that has been mentioned in this and other threads. Nothing works as effortlessly as this stuff. Almost no elbow grease required other than to wipe it on. And no harm to the gel coat, which you can not say about most other cleaners.
my .02
my .02
I have been using nothing but "The Works" tub and shower cleaner for 3 years. It actually leaves your hull feeling slick. Anything that is going to remove the yellow has got to remove the wax in order to get to it. I havnt tried these others. Give The Works a try, one bottle does my 26 Liberator that likely has more hull in the water than most bigger boats
Did some one mention cleaning exhaust???? I'm looking for a good cleaner / polish that will take off the baked on soot or whatever you want to call that stuff on my exhaust tips and make em shine again.
I use a product called dri-wash on my boat works great wipe on wipe off. Here are some pic's.
http://www.angelfire.com/nb/detailli...with_boats.htm
If you want a traditional cleaner I picked up some starbrite hull cleaner at ACE, to clean the bottom before I applied a speed coat this worked well aslo. Brush on Spray off. Only bad thing is it contains some acid.
