Floating Trailer Issues
I bought a new trailer LOL, really a frustrating thing especially when loading in a current, I had a builder tell me once to back in water and go have lunch, once the wood soaks up a little water there like lead weights LOL
I have load master triple and trailer never floats. Fresh or salt... always heard that up north, ppl prefer steel for that reason, but my alun never floats. I back in just enough to cover fenders and front bunks with no issues and drive boat up.. latch and crank i f needed.
Forum Regulator
The only ones that do it are the aluminum bolt-together trailers with long/large wood bunks.
Often the frames are quite short in comparison to your Manning; as they end them right after the axles and use the wood bunks to extend off the back to meet the transom. This is part of their cost cutting technique; again--all pending the manufacturer. Some are built better than others.
Triple axle trailer more likely than a tandem.
16" tires on aluminum rims, more likely than 15" steel rims. etc. etc.
All the above will work. We have a easy no cost process. Back in the trailer in but not so far in that it floats. Drive the boat about 1/3 way up the bungs and the driver walks down the trailer with the wench strap in hand & connects. Driver eases the trailer into the water while you are cranking in the winch strap....pretty easy. Wife can't help?...maybe your girfriend can. ![Big Grin](/forums/images/smilies/biggrin.gif)
Ginger or Mary Ann?
Also 2 extra tires filled with air..
Thanks for the recommendations!
I have a tandem with no guide poles. It is a "bolt together" trailer. I can see how the long bunks in addition to the four tires don't help. The trailer holds a Sunsation 288 so there is plenty of wood to add to the bloating issue.
I've tried backing in slowly, dunking the entire trailer and pulling out, and many of the other recommendations from above. I'm not a novice but would like to think I exhausted every solution before bolting weight to the trailer which seemed to be the best solution outside of buying a steel trailer.
Seeing that I boat in only freshwater I could go either way!
