Altitude at LOTO
Do you want to know the altitude at water level or at the airport ....? Depends on how much water is in the lake, usually around 650. Today 658.63 water temp 85. What do I win?
TS
TS
You probably need to know density altitude then if you want max performance. I would bet with 90 degrees and 60% humidity you may be up to a couple thousand feet in density altitude maybe more. All my plane stuff is packed away but some of the pilots on here could run some rough calculations for you.
Gone Fishin'
It's not so high that beads fly better.......they seem to fall JUST short of some of the lovelys. If it were higher, they would fly farther!!!!!
Buddy OO
05-20-2005 11:05 AM
